W WHUMSY New member Equipment KUBOTA d1005 Feb 14, 2022 4 0 1 32043 Feb 18, 2022 #1 Hi there, I need help to take off this flywheel, off a Kubtoa D1005 on a boat, not sure if it slides out? I can't get it to budge Attachments 20220218_111021.jpg 574 KB Views: 144
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 30,206 6,378 113 Sandpoint, ID Feb 18, 2022 #2 Take the center hub out, the part that has the plastic ring behind it. Then there will be crank bolts behind it.
W WHUMSY New member Equipment KUBOTA d1005 Feb 14, 2022 4 0 1 32043 Feb 18, 2022 #3 The flexible shaft coupling is bolted to the flywheel and also to the center hub, and getting to the bolts requires somehow taking off the flywheel first.
