How to Reset Engine Error Codes L3560
SqueakyL3560
L3560
Jun 2, 2018
MN
Hello All!
I recently bought a new L3560 and it threw engine code P0336 after 10hrs.
I googled and came to this site, but could not find specific instruction on how to reset the ECU and clear the code.
My dealer gave me the instructions so I wanted to make them available for you all.
Please reply with other codes/Info so people that need this info can come across it easier.
Thanks for your help!
OK The website is not allowing me to upload the actual docs. So here is info. This applies to tractors with the Intellipanel style dash.
1. Press Display mode button and hold
2. Turn Key to On
3. Several modes will appear
4. Press Display Mode until "D" is highlighted
5. Press and hold display mode for more than 2 seconds
6. "Want to clear codes? Hold button for 3s more" Will appear
7. Press and hold Display Mode for 3secs
8."Cleared" will appear
9. Turn key to "off"
Then your computer should be reset. Mode "A" is a diagnostic mode and gives information about your temps, rpms and volts going to switches on the unit, kind of neat to look at and could be helpful in the future.
sheepfarmer
Nov 14, 2014
4,451
679
MidMichigan
Thanks Squeaky, great post. The information is floating around here, but much nicer to have it under a title that will pull it up with a search!
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the OTT forum Squeaky.
Thanks for the info.It just might save someone else smoe headaches.
SqueakyL3560
L3560
Jun 2, 2018
MN
I forgot to say I believe this will work for the L4060, L4760, L5060, L5460, L6060 tractors.
The P0336 code is a Crankshaft position sensor code, that can be thrown when the engine almost stalls several times. When computer sees this code, engine will only operate at 75% of power.
jryser
427
Plainfield
Thank you for this quick info - took a snap of it and saved it to favorites! Welcome!!!
Maple Man Dan
B26 TLB, L3560
Jan 3, 2019
Nova Scotia Canada
if you get the error 20 code when trying to start in a cold area on a very cold day the relay for the glow plugs can freeze. if you turn the key to the run position and leave it there for 2 or 3 mins it will heat up the relay. Clear the error code and try starting again.
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
441
34
Atascadero
Welcome to the "New World" of sophisticated electronics, exhaust treatment and various sensors on tractors that should have been left alone.
I have a 2007, 5.9 Cummins powered Dodge pickup and experienced "LIMP" mode while towing a heavy 5th wheel trailer. NO fun towing with 50% power!
sheepfarmer
Nov 14, 2014
4,451
679
MidMichigan
The 01 s have a different screen. Do you have a shopmanual? If not I can see if I can find the directions for you if you need them now.
