We purchased this tractor and loader in 1993 and use it around the farm primarily to move and load round hay bales. I would like to remove the loader but cannot locate an operator's manual or video online describing how to do this (*safely and in a way to re-install easily. A manual for a smaller LA526 loader describes lowering pre-mounted supports from below the loader arms. But mine LA1150 does not have these. There are two (2) 0.758" diameter pins welded to the lower side of the arms. Also there are two (*2) bars stored across the to vertical loader posts but the drilled holes are two small to fit the 0.758" diameter pins (*only 0.629" diameter) Here are some photos. Looking up the /N I find this L5450 was built in 1989, she's an older model. Any and all help is appreciated!
