How to remove PTO shaft
Sam427
L3410 GST, FEL, Bush Hog, Box Scrape, Spreader
Nov 6, 2009
194
Snellville, Ga. USA
Hi, I just got my first tractor, a used L3410 GST. It came with the bush hog attached and I took it off to attach the box scraper. The front half of the shaft is still attached to the tractor and I am not sure how to remove it, and the manual hasn't shown up yet. It has the plastic tube and plastic shield over the u-joint and I can't see what is going on there real well. Looks like it may have a pin or a bolt holding it on the shaft. How do I remove the shaft?
bruceatlam
B20, FEL, box blade, flail mower
Aug 20, 2009
410
Camarillo, California
With tractor shut off, reach in under the PTO guard and grab the end of the shaft that slides onto the PTO splines. You should feel a pin sticking out --- press the pin in while pulling on the shaft at the same time. The shaft should slide off of the PTO splines.
