How to remove an engine
armylifer
Mar 26, 2013
2,061
787
Thurston County, WA
I have never seen anything like that in all my life. I'll bet that someone did not tighten the transmission bolts. That engine came out of there just too clean for something to not have been tightened properly.
8upbowhunter
L4701 FEL, Cutter, Discs and Land Plane
Dec 15, 2016
397
59
S/E Louisiana
Once those motor mounts went under that much torque the transmission bolts won't keep it in there lol.
5,687
Go back and look at it again about a dozen times. Go to the bottom of the picture where it says "source". There you can stop the video. Stop it a few times. You'll see the block itself separated just above the crankshaft. Crank, bottom 1/2 of the block, con rods and cam all stayed in the engine compartment.
Pistons stayed in the top part of the block with heads still on. What you see at the end, is the top 1/2 of the engine and are looking up into the cylinder bores from the bottom side. Head are still on top of that part of the block.
