How to 3D print Switch Panel
Tayschrenn
LX2610su |-| La535 QA |-| 60" Bucket |-| PFL2042 |##| JD X580
Oct 28, 2020
Has anyone done a 3D printing of something to fit inside this 'holder'?
My thought is to either 3D print something to fill in the gaps of an existing NiLight switch box (I have one that fits inside but is loose) or else custom print one. My biggest unknown is how to get the measurements right for some of the curves inside of the holder.
I have access to CAD programs and 3D printers (my company has a couple that employees are allowed to use) but the actual measuring I'm unfamiliar with.
Of course if someone has already done the work that'd be even cooler =)
2,526
I have 3D printed a ton of stuff - the printing part is easy ! NOW as you mentioned the measuring part can be rather tricky on rounded items.
You want a panel that covers the top? And then add the switches to the panel?
Would it be better to start from scratch and leave the OEM tray OUT and construct a new "box?"
Tayschrenn
Oct 28, 2020
The problem with leaving the OEM out is that it has the 12v outlet as part of it; i'd rather not risk messing that up. But, it's possible! That tray is clearly designed to come out / be replaced.
Tayschrenn
Oct 28, 2020
Oil pan 4
L185 turbo
Sep 21, 2017
418
117
NM
That's pretty cool. Being able to fit inside of , go around any obstacles and arrange the switches any what way you could want is sweet.
4,876
If you want just a 'lid' for that 'holder', getting accurate dimensions will take about 15 minutes and $4.
Geta thin sheet of plastic,like a cheap plastic bag, place in holder, shake a can of spray foam real good and fill the holder, wait until cured, remove the foam 'template'. Remove excess to get 'top line' . Use bandsaw or bread knife. It'll be 100% accurate. As for getting the dimension into your 3D machine, yer on your own. My guy simply takes 4-5 pictures,imports into his program,adds2,3 dimensions, then program does the 'math', sends data to his CNC machine. He cut all the code himself as well as design/build the CNC machines.Biggest is 5by9, feet, accurate to .01 thou, cost less than $500 for parts.
mikester
M59 TLB
Oct 21, 2017
3,527
1,987
www.divergentstuff.ca
My car has a Qi wireless charging tray for my cell. The tray is so big that the phone slides arounds while driving and stops charging. I made a drop in tray liner that lets me drop the phone into the right position and hold it there.
The tray worked good until the heat from parking the car in the sunshine caused the tray to shrink and warp. It no longer holds my phone due to the shrinkage.
3D plastic printing is nice for making 3D mockup models but is useless for real world parts.
4,876
well if you use the proper plastic, you can fire 22 rimfires from 'plastic guns' all day long....
it gets kinda HOT inside a car on a sunny day, so you have to read the plastic material specs.
for my 'good everywhere' products, I spec and use 'automotive rated' computer chips instead of industrial or commercial. Cost isn't much more, maybe $2/board but ZERO problems.
