How much does a Bx23lbm weigh
Cglaza
L2500DT, BX2380, G6200H
Aug 30, 2015
170
Freeland, mi
A trailer with double 3500 lb axles should do the trick for ya (with brakes of course). Judging from my L series you shouldn't be more than 4000 to 4500 lbs.
Sent from my moto z4 using Tapatalk
dsims
BX2380 60"Drive Over/SSQA Loader
Feb 23, 2019
35
Clear Lake, IA
You are probably between 2000-2500 lbs. A single 3500lb axle trailer would be overloaded more than likely, although its been done. I know the BX2380 is around 1500, another 400 for the loader. Not sure what the BH weighs, but I'd guess 400-600.
5,214
1,896
The newest BX23S shipping weight is 2475 including both buckets. If ordered with the 3 point hitch, add 50 lbs (2525). There is no crate, just a couple blocks of wood and an orange ratchet strap which amount to under a pound.
May add 10 lbs or so for any dirt that might be built up in buckets and or around the undercarriage that you might not be able to see.
Add about 400 lb for a belly mower if you have that.
Mechanical thumb is about 45 lbs total.
third function is gonna be about 70 lbs (fittings, hoses, etc).
The older generation BX TLBs aren't much different in weight; they're almost the same identical tractors as the newest BX23S with minor differences that amount to nothing, weight-wise.
PA452
B2650
52
Western PA
I owned a 2006 BX23 TLB until a couple months ago. The dry weight of the tractor with FEL and backhoe is 2700#.
I used a dual axle 7000# landscape utility trailer to haul it for years. Wouldn't suggest a single axle.
