how many stock Kubota Injection Pump Shims on d950
ASTER
115
ROSEDALE LA
how many stock Kubota Injection Pump Shims on d950 an what size are thim?? also what if there is no flywheel intalled on the tractor how whould you timing the pump?
8,718
There is no set amount of stock shims, every block is different, hence the need for different size shims.
If there is no flywheel how do you start it?
It also won't do a whole lot of work without a flywheel to keep the momentum and torque up.
ASTER
115
ROSEDALE LA
well how many shims do you have on your d950/
SDT
multiple and various
Apr 15, 2018
3,311
1,101
SE, IN
The answer to your question is meaningless.
The timing is set by adding or removing shims. This is initially done upon manufacture and subsequently done any time that the injector pump is removed or there are indications of questionable timing.
Each engine is different.
SDT
ASTER
115
ROSEDALE LA
SDT
im trying to find a good number to start with, i dont have any on there
8,718
I have a D750, a D850, and a D950 here and everyone is different, different count of shims and different thicknesses of those shims, there is no "set" number or size.
What happened to the original shims?
Is there a flywheel or not?
And if not how do you start it?
And how do you connect to it?
To set it right , you need to do a spill test to get the number needed.
So put the pump in, test the amount that your off, and get the exact number and size you need.
ASTER
115
ROSEDALE LA
i dont i installed the flywheel right, also motor i bought did not have a pump or anyshims the guy thought it was gaskets, im just looking for a good number to start off
8,718
I'm trying to explain to you, you don't need to start with any, put the pump in follow the procedure to spill test it and then you'll have your answer. ;)
