How big a tiller?
jhillsmo
B1750HST deck mower, disc harrow, post hole digger, chain harrow, powertiller
Oct 15, 2010
perry,mo
Want to rent/buy a tiller. What is correct size for B7510HST?
Kytim
Aug 14, 2009
848
12
Western Ky
Hello, Your tractor has 17 PTO Hp. And really the MAX tiller size would be a 48". In my experience it, 48", would use every one of those ponies in heavier soils like in the mid-south and south with it's higher clay content. Your area my be better and thus, not so hard on the tractor. If I was to buy another new one it would be a 44", but then again I have a B7100 w/ 17pto hp.
Good luck.
hodge
Nov 19, 2010
2,906
453
Love, VA
I second what Kytim said. I have a 48" for my B7100, and it pulls it good in my soil.
The 7510 has 5 more horsepower than the 7100, so unless you have some abnormally dense, hard soil, your tractor should handle a 48" fine. If it were mine, I wouldn't go larger, though. Rule of thumb is 5 horsepower per foot, so 4 foot put you in the ballpark.
sicilyb6001d
palo alto
What type of tines on rotortiller
Hi,
my B6001d tractor is equiped with a rotor tiller on which the Model I am not sure of. I am assuming it is the RS 1351 b/c it looks like the ones I see on the web. I have taken one of the tines of and 287R is stamped close to the bolt. Can anyone make use of this number, to help me find the right tines to buy? or perhaps a place where to buy.
thank you very much.
ecook280
Kubota B8200HSTD
May 1, 2012
34
I am running a 48" on my B8200 19 HP and it works great, I wouldn't want to go bigger on mine and I would think at 17 HP you would be OK with 48"
Kingkubota
B7510 with fel,60"tiller,disc,72"mower,post hole digger
Aug 8, 2017
10
humboldt
I have a 7510 with a 60 inch tiller and it will till unbroken ground fine.
