Honda GX 270 9 HP engine w/ 6 gpm hydraulic pump, hydraulic oil reservoir & 2-way valve - AS-IS
retiree-urgency abandoned
B3350, Kub. 5" rotary cutter, LP 48" forks, Titan Aerial Platform, KK XB Dump
Dec 1, 2020
71
68
Bloomington, IN
Hi - these are some parts I don't need as a result of cannibalizing a Compac portable auger to make a tractor-mounted auger. 9 HP Honda engine - has a little gas in the tank (not sure how old), I tried to start it and doesn't start, but didn't go any further. Recoil starter slow to retract, but does with patience. Hydraulic pump is attached to the motor. also comes with hydraulic fluid reservoir (on 2 wheels) and 2 way valve. Selling as-is, where-is. It's on a pallet, so I can load it onto your trailer or truck with my forks. OTT price - $100. Located in Bloomington, IN.
Dec 1, 2020
71
68
Bloomington, IN
