I have a b1750 and having a bit of a challange getting my single turning plow to align properly. I can get the depth right, but aftern turning a row then putting the right side wheels in the furrow, the plow is just a little too far left and leaves about 6inches of unturned ground. The ground I'm then turning doesn't completely cover that unturned strip. I have moved the plow as far to the right as I can go and have played with the 3pt. hitch links some. I do have the rear tires set at the wide spacing for safety. If I put them on the narrow setting, would that fix my problem? For more background, I am running in low 2 most of the time and in north ga mtns red clay. I do wait until rain to soften things a bit and amazed what this little tractor can do even though just a 2wd model. Thanks for any ideas.
