So, my 2160 has a weird thing I think is related to 2 issues. Misadjustment of the speed/direction control system/linkage and quite a lot of wear.
The machine is ridiculously fast in forward. Literally "scary" fast. Running along at near 20 mph with engine on the governor and pedal full down. However in reverse can barely get out of it's own way. One issue I think is contributing heavily is the "play" in the pedal and linkage. From neutral position there is about 1.5" of free travel in either direction of the pedal. So when in reverse the pedal "bottoms" out while barely "engaging" the hydro. I have gone under the machine and noticed lots of play in assembly labeled D520XX in the part diagram. Yet I cannot find it in replacement parts. It also binds up. So looking for some advice on how to tighten things up, stop the binding and get the forward and reverse speeds back in order.
