Help with L 35 age
bruceatlam
B20, FEL, box blade, flail mower
Aug 20, 2009
410
Camarillo, California
Not that I'm aware of ---- best advice I can give you is check to see if there's a maufacture date stamped in the back wheels. If there is, the only assumption you can make is that's about the date that the tractor was assembled.
Vic seems to be better able to pin down dates of manufacture -- maybe he'll chime in here.
pat331
L35, mower, bushhog, cement mixer, grader, boxblade, forks, posthole digger
Mar 31, 2009
298
Ft. Worth, TX
I meant to look up the serial # on my L35 and keep forgetting. I bought my L35 used in 2003 and was told it is a 98 model. I decided to get proof it is a 98 and was told by the Kubota dealership that the "official" year of the tractor is based on the date it was sold when new. I found out mine was sold new in early 1998. I agree with the advice to check the manufacture dates on the tire rims. My rears have the date 10 28 97 stamped on them and the fronts have 12 97 stamped on them. Both were made by Titan. Hope this helps.
