Help with Antifreeze leak in my bx2200
tkops
bx2200, fel
Nov 30, 2010
ct
Hi all,
I just found this site after 4 months of picking up a used bx2200, some great info on here.
in any event, i live here in ct and everything has been fine with my bx2200 until this past weekend. The temp dipped into the low teens at night and when i started my tractor and let it warm up, i noticed antifreeze on the ground. I am not too familiar with the tractor, but i noticed there was a little puddle right under where the engine sits on the ground. It did not come out of the overflow as it was dry around it and that resovoir is only filled up about half way. does this have anyting to do with the change in temperature, losing pressure maybe? any suggestions as to what to do?
thanks,
Tkops
OrangeRidge
70
Queensland Australia
Take the engine covers off and check the pipes . It's a really
small system compared to a SUV etc. You should be able to
see staining . If you're lucky , it will only be a hose-clamp tightening
required. If you can't see any clues , start it up and get it to temp
and pressure.
