help with 20.5x8,00-10 tires
richie25rich
warrington,pa
I need help finding new tires for my Kubota B1750-HSD. I use the loader alot and they are dry rotted and leaking. I can put tubes in but the tires look like the sidewalls could blow out.
Kubota wants 250 dollars American for each tire----crooks!!!!!
Does anyone know where I can get those tires? I live in Pennsylvania hour North of Philly.
Rather than giving kubota all that money---------I was thinking of keeping the rims and buying new front and rear tires that will have the correct size ratio when using 4 wheel drive. does anyone have any suggestions?
I might be able to get trailer tires, and then purchase an electric tire graver that will heat a blade and then cut groves in the tire tread to improve traction.
Any suggestions would be greatly appreciated!!!!
Thanks!!!
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
302
northern lower Michigan
Look at the subjects in this section and you'll see that Firestone now makes the 21x800-10 again which has exactly the same rolling circumference as the 20.5-8-10 Bridgestone turf tires you're trying to replace. Actually your tractor could have come from the factory with either tire/size depending on which tire happened to be available when they built it.
Want to buy tires go to a tire dealer in your area preferable one that handles commercial type tires although any dealer you pull into if you tell them what you want should have no problem getting them for you.
Don't know why people tend to go to a tractor dealer for tires nor would I expect them to go to a tire dealer for tractor parts just because the majority of tractor dealers do not even sell tires to much degree. The price that may have scared the $hit out of you in price I would bet money was because they went to their Kubota parts and because it came out of the "orange book" more than likely why the price may have been that high not that they were marking it up more than some think they should.
It's all about finding the most direct source from some business that specializes in what you are looking for.
Al
