Help log skidding
Manvito
Kubota B2601
Apr 27, 2016
106
New York
I just bought a 3 point hitch to reciever for my B2601. It was on Amazon for $106 shiped. I also got a 3/8th” clevis grab hook to attach to the D-ring that’s on the reciever. I’m planning on choking logs with my 3/8ths chain, hooking the chain to the clevis, raising it with the 3 point hitch and skidding them out of the woods. Does anyone have any tips while doing this? Does it sound like a good, and safe idea?
bcp
BX2360
Apr 20, 2011
644
80
SW WA
A 3/8 grab hook clevis probably won't fit over the D-ring. Mine will only fit the same diameter as the hook does. Your D-ring may be 1/2 or 5/8 size.
Add a hitch insert with a hook, etc, so you can pull with it, after you lift with the D-ring.
Bruce
3,075
skidding is an art form, it aint just lift and pull, lot of bad stuff can happen while doing that. Get a skid plate, that way you lift, place plate under and then pull - why is that better you ask? IF/when you hit an unseen object, you front end does not come up and make you change your shorts!
seems expensive - but worth it.
https://www.ebay.com/p/Log-Skidding-Plate-and-Chains-Tmw-21-by-Timber-Tuff/1711937070
or make your own - the 3 point is great to lift the front end of log, but really bad to pull it the entire trek through the woods.
Manvito
Kubota B2601
Apr 27, 2016
106
New York
I never saw a skid plate before, I will look into it. I already have a little bit of pucker just knowing how dangerous any kind of tree work is. Thanks for the info.
Ridger
L3940 HST
Nov 26, 2014
170
22
North LA
You may want to look at a skidding tong. Lift the end of the log closest to the tractor off the ground as close to 3 point hitch as you can, drive slowly, and be careful. I lost a good friend skidding a log too far back behind his tractor. The log snagged a root and his tractor walked back on top of him.
3,075
"The log snagged a root and his tractor walked back on top of him"
exactly what I was mentioning........and the higher the log get up in the air behind the tractor.....the more WEIGHT you are pulling!
SLow and careful......best words .....period
baronetm
L3901HST w/FEL, 3rd fnct. BH77 BH, 5' Bushhog, 6' BBL, 42" Forks, WoodMaxx WM-8H
Apr 19, 2017
122
12
South Central VT.
A log skidding horror story, many years ago my brother in laws father owned I believe the first Kubota Dealership in Vermont circa early to mid-70’s. Not long after this ownership started the service work also began to come in. I went with my brother in law and on a service call into the Vermont woods in January to look at a tractor the owner said broke, what I can remember with no more explanation than that, broke. Upon arriving at the logging site after about 45 min to an hour of walking we found the tractor, a large framed Orange beast for its day, I would guess about 35-45 HP, I do not remember the model. Yes, the tractor was broke, literally in half, hanging on 2 bent bolts and a guide pin between the engine and transmission housing. We stabilized the frame by placing logs etc. under the engine and transmission to keep the tractor from completely coming apart and left to return another day with more than a small tool box of hand tools.
The owner was skidding logs with the FEL, yes, hooking chains to the welded bucket hooks and attaching them to the log. It appeared and the subsequent conversation with the owner confirmed it. What had transpired, he was skidding full length tree logs 8”-12” in diameter for firewood. My recollection, this particular log was a 20-30 foot long and it got hung between some standing trees and the owner kept pulling trying to free the log, he said he had done it may times with no issue. To my recollection there was no damage done to the FEL.
Upon returning a couple days later with another tractor and a lot more than a small toolbox we used come-along, chain and binders along with a small I beam to pull the tractor back together and support its broken back. I do not remember how long it took bind and tow the non-running tractor out of the woods but remember being very cold and most of the day being shot. Fortunately no serious damage was done to the tractor as I recall beyond some slightly pulled threads and chipped bolt holes. A couple days of drilling the broken bolts out and re-tapping threaded holes, the tractor was put back together with no apparent lasting issue. I do not know if the owner of the tractor continued logging in the same manor after its return. This failure did give us the idea to make a small log winch similar to what you would find on a commercial log skidder of the day with success. We used a Woods PTO Hyd pump for power, but it was too expensive to manufacture or sell at the time so we owned and used the only one made.
I would guess the moral of this story is to use the equipment as intended, and if it looks like a bad idea, it probably is. And, just because you got away with a bad idea once does not ensure you always will.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
OK here is a worse story. A friend of mine used his Christmas vacation to snake logs out of the woods for fire wood. It was a Ford I think, no roll bars. As he pulled the logs with a chain secured somewhat above the axle now and then the front end lifted slightly off the ground, but no problem then. He didn't get all the logs, but went back to school. So the old man decided to go out and get that last log. He didn't come home as planned. Back in the woods they found him dead under an overturned tractor that flipped up the front end over to the back crushing him against the steering wheel. So ya got a roll bar? Maybe you won't get squashed there, but what is to protect you if the fall is sideways upside down? The answer is NEVER PULL FROM A LEVEL AT OR ABOVE THE HEIGHT OF THE REAR AXLE!!! THAT THREE POINT ONLY FILLS THAT RULE IF YOU ONLY USE THE BOTTOM PART, AND BARELY THAT.
Manvito
Kubota B2601
Apr 27, 2016
106
New York
You guys make me want to stay home on the couch! Seriously though, there is a lot to think about. So the setup I have is junk, unsafe, or both? I will certainly go very slow with whatever I use. A friend and I plan on cleaning up tree tops that were left after a logging operation, and using them for firewood, I don’t think any of it is real big. I even considered dragging a small trailer and using my grapple to load it or loading my carryall and my grapple and making many trips in and out of the woods. We aren’t in any big hurry so I’m guessing whatever is more safe, even if it’s slower, will be what we do.
9,118
I've dragged some logs with my L1501. I just used a clevis hook attached to the draw bar on the 3 point lift arms. Just kept the arms lowered.
Back in High School. Dad had a true logging winch for his L2250. Logging winch was for a 40 hp and up tractor. But the L2250 handled it well. The logging winch was a Beast. I could run the cable out and drag four 18 to 24 inch trees up to the tractor in one shot :cool:
Now getting that load out to the landing was a rodeo ride :D
Sent from my SM-G920V using Tapatalk
helomech
527
East Texas
I have dragged lots of trees with my 5100, with nothing but a bar across my 3 pt arms. Never had any type of issues, and many of them where around my pond and in my pond (after I cut them). No flat ground around. I guess that is another huge advantage to a hydro tractor, if anything happens, just let off the pedal.
maclean
BX25D
Jun 25, 2014
242
Lowell, Or
Skidded lots of logs with my BX25D. Dragged the backwards with the chain wrapped around the front frame/grill guard.
Go slow and wear the seatbelt.
