Hey folks,
I may be answering my own question but just wanted other opinions to keep me honest
. I have an L4060 with a quick hitch. I had recently purchased a rotary cutter however when I was assembling it the PTO shaft was too short when in use with the quick hitch. The brush cutter worked fine but still vibrated a little.
I had taken my PTO shaft to my local tractor repair shop and they only had material to lengthen the inner shaft not the outer. So my question is does both the outer and the inner shaft have to be the same to keep the balance? If so do you think because the inner shaft is twice as long as the outer that would be causing the crazy amount of vibration?
All input would be appreciated! Common sense tells me its the PTO shaft, but just want to get other opinions.
Thank you,
Page546
Thank you,
Page546
