I love my Heavy Hitch dual offset rack. Very compact and unobtrusive compared to the 5' box blade I was using for loader counterweight. (My tractor shed is a narrow one-car garage.) The almost 250 pounds I usually have on the inner rack has been perfect for the constant mulch moving I've been doing all year. And has worked well for dirt. I am not sure it's technically enough for dirt, though my quick hitch and the heavy hitch frame itself add another 100+ pounds (my tires are also filled). For lifting logs with the grapple I'd load the rear rack.
My question is does anyone use the Heavy Hitch Weight Cart? Their standard-duty model is $312, plus shipping, and they have a new heavy duty cart, which costs $407. The lighter weight of the regular model, 44 pounds vs. 88, appeals to me—easier to handle. But I definitely want stability and durability. Once it gets here, I'll probably set it in a spot and leave it. I don't have enough cement or level ground to offer it much more protection than a tarp on my flattest gravel spot.
I really don't want the cart falling over if I have only one side of my hitch loaded. As I indicated, I typically load the inner rack closest to the tractor with six 41 lb. weights. Somewhere I got the impression this unbalance would cause the cart to topple over, and I'd have to put some weights on the back rack to balance things. My old, bad back protests when I handle weights ,so I want to do as little weight lifting as possible.
The nice person I spoke to today at Heavy Hitch said toppling in this situation shouldn't be a problem. I'd like to hear from a user on this as well. My grandchildren are around, and there must be no chance of toppling!
My own attempt to make a 2x4 stand has not worked . . . It DOES topple!
I'll attach some photos of my hitch loaded front and rear, just the front or inner rack, and my dangerous makeshift stand.
