Heart acke house tales:- that NEVER ending Job, the Access & "THE" Tool
koppel
26
Melbourne,Australia
Hi again all,
well though I would share some of my pics and give you an idea of the earthmoving portion of our house renovation "fun".
Stated by us buying a house in the Victorian (Australia) "high" county, on a steep sloping block. Clay base, lots of rain and no driveway access to front yard. AND termites damn termities.
One crap 2m (6ft) high retaining wall crossing, from side to side under 2/3 of the house. Will need to be completely redone.
Rear of propery is accessed by 80m (263ft) gravel creek bed AKA Driveway, that slopes at 22deg; to a semi level 8m X 10m pad before then rising a further 3m via a 40m ( 130ft) 1/2 circle drive to back pad behind the house.
Only a steep wide path up one side of house from this rear pad area.
Well I started 2 years back, repairing and building retaining walls.
The most critical was the one under the house (split level at rear). I used my Kubota KH-007 mini excavator and we pulled out 8 cu meters of clay and rock and built a 2m (6ft) high concrete sleeper wall held in place by heavy steel I beams. But that another tale. Its only 30% finished so far.
Anyways I lashed out last Christmas on a second hand 4wd B7100HST and added a box blade. Initial reasoning for it was to try and maintain the driveway after each heavy rain storm washed it away. Eventually it will be surfaced.
It soon became obvious that I needed a front end loader for this machine.
By May (2010) I found a second hand loader in poor condition. Finally after many delays, its repaired enought to use (Sept 2010)
So here is FEL's first job.
Removing about 12 cubic meters of saturated clay that I had excavated using the mini excavator to build 2 of the 6 retaining walls that will cross the front of my block.
This is one Access point to the area in front of house to remove the clay.
Its a steep winding goat track most likely with not provide simple access and has NO where at top to dump the clay.
Access way 2. the better choice of access, but steep as you can see.
Using this access from clay pile to my choosing dumping spot is about 75m ( 246ft) all down hill.
this is job entrance!! TIGHT and boggy
My lady friend had just finished adding the bamboo fence, on left of photo last week, so it was prefered to NOT damage it.
After almost getting my B7100 bogged I used my trailer ramps to bridge the boggy enty
So here is the fab tool I am using
And yes I need to build a counter weight box. But for now at least choose to hang those 3 counterweights on the 3 point linkage arms. Made a huge improvement in stability.
And here is the tool at work
2nd view of the job
3rd view of the job with the pile of clay that I need to remove
4th view of the job showing how limited is the access
5th view of job
well that is for now.
So glad I have a ROPS and seat belt. Mind you I am taking it slow and easy and keeping loader bucket low to ground.
I cannot turn around at clay loading area so have to back down to the top pad landing before doing a 3 point turn to then be able to drive forward down the curved drive way to the dump point.
Tomorrow I will continue the clay removal weather permitting.
regards
david
Jimmysal
B1750HST, RC60 MMM, LA300 FEL, TSC 48" BoxBlade, PTO Dbar chains tongs old Stihl
Aug 26, 2010
24
Vermont
Re: Heart acke house tales:- that NEVER ending Job, the Access & "THE" Tool
Wow, that's pretty tight. Any chance you can cut some of the shrubs back in the 4th view so you can bang a K turn right past the roll of blue material?
Also, I might be inclined to move the bamboo fence just in case!
Keep us posted!
gazza
Melbourne Australia
Hi David,
you certainly picked the best winter to do some earthworks;).
For those readers who don't live in Melbourne we have had about 7 years straight of less than average rainfall, yet this winter is very wet.
Just curious, how do you go dumping the clay out of the bucket, is it better to have it wet and slippery or a bit drier.
cheers
Gazza
Jimmysal
Aug 26, 2010
24
Vermont
As far as handling hard clay, I keep a bottle of WD-40 on me when I'm working. I'll spray down the inside of the bucket if I notice the material sticking to the inside. If the clay is somewhat "cured" I'll rough up the pile with the scarifiers on my box blade before moving anything with the front end loader.
koppel
26
Melbourne,Australia
Jimmysal,
thanks for your good thoughts.
I got told (nicely) if I "really" need to move the bamboo fence I can.. but so far I have been able to work around it. My friend health has been poor in recent years so I try not to undoo any work she has laboured to do.
As to moving the blue coil and cutting back in pic 4 that not possible since its a narrow tract sloping Up a compound 12degs and angled badly. I would need to raise the bucket to near full height and that would be asking to for trouble..
1 i be likely to tip over and if not
then
2 i would certainly hit the 240Vac over head power line to house and Zap it would be over for me.
You can see the aerial power connection sticking up out of left hand end roof of house in pic 4 just above the veranda post.
sadly its drive in up hill, turn left at sloping ankle then .. back out same way as i came in.
Jimmysal
Aug 26, 2010
24
Vermont
Ah, didn't see that in the picture. Is there enough room to do a K turn up by the pile with the bucket facing away from the house? Sort of swing the front loader over the lower wall and back up near your water heater. Maybe move some of the potted plants for safe keeping?
Can you use the clay as backfill for any of the retaining walls?
dusty-t
974
Mountforest Ontario
Wow what a project. You will have things to keep you busy for years to come. I envy the interesting work you have to look forward to, I don't envy you having those slopes.Awesome thread , keep us posted.:cool: Dusty
