Happy Block Heater Day!
How many people are happy they have a block heater this season?
  • Dont have one, wish I did.
    Votes: 5 21.7%
  • Glad I have it.
    Votes: 16 69.6%
  • Would not buy another one.
    Votes: 3 13.0%
  • Total voters
    23
GrumpyFarmer
4,643
This summer my buddy picked up his first tractor ever, a really clean L3302 (used) and opted not to have a bloc heater installed in on the deal. I was not able to convince him🙄. I did convince to treat fuel though. Today, driveway drifted over, and it was his first no start.😥
I’ve had one on each of my machines and I think it helps… can’t imagine all that compression on cold rings is good for them…got to be hard on the engine and if a real cold start.
anyway I am curious I am the oddball with the bloc heater or not (yes I understand block heater is not the main contributor to me being odd😉)
10,183
I've had block heaters in all four tractors, and have them in both trucks and use them regularly. I wouldn't have a diesel truck or tractor without a block heater.
WI_Hedgehog
Apr 24, 2024
1,047
1,470
Milwaukee, Wisconsin, U.S.A.
Honestly, it's no longer about starting, ECUs and injectors solved that problem, it's about wear. Oil doesn't flow well when it's thick like molasses, and that's where a block heater helps greatly. I have a block heater, oil pan heater, and rear gearbox heater for the hydraulic fluid because I love my Kubota.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
905
873
E.
block heaters here are not even an option anymore here.
I don't know of any car, truck, tractor retailer that sells new vehicles that don't already have them installed. They are standard equipment here.
3,777
I was “trapped’ (sort-of) into buying a Cummins-equipped Ram 2500 last year…. and was pleasantly surprised to read All Cummins had factory-installed block heaters.
(Perhaps this makes-up (in some small way) for that traitorous Grid-Heater.)
Typical of my luck…. the very next version of this engine dumped the hazardous grid-heater and accepted the industry-standard Glow-Plugs. I always seem to get the last-versions of poorly-designed products. :cautious:
Anyway…. during this wide-area-freeze I’ve kept the block-heater plugged-into power….. while I stayed at-home next to the fireplace the entire time. Never even tried to start it. :ROFLMAO:
4,608
Thank you sir!
Reading this just reminded me to go plug mine in.;)
5,529
Don’t have one because it didn’t come with one and it’s parked in a climate controlled shop that stays between 65F and 75F year round. If it was parked somewhere that got cold, I’d definitely have one.
mdhughes
L3901DT
Dec 10, 2014
1,407
1,313
Ste Geneveive county, MO
After having the block heating sitting in the box for 6 years, I install it this last Aug. I never had a no start problem, but it would auto idle up when it was really could out. Now with the block heater, it doesn't do that and it sounds a lot happier at 10°F when I start it.
Like WI_Hedgehog said, it's about wear.
forky
L2501 HST 4X4 8N BB 1266 Box Blade RTA 1258 Tiller QH10 48" pallet fork s
Feb 23, 2021
327
362
Wisconsin
I would not be without one either. It never went above 0 here for the last 2 weeks until today.
My dealer does not have any new tractors without block heaters. He said that with the weather we have here, it's a no-brainer and worth the cost.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,759
2,203
Western MT
I voted glad I have it, but we haven't had much snow. That means the tractor isn't plugged in since it isn't going anywhere.
WFM
L3800
Apr 5, 2013
1,570
1,042
Porter Maine
Mine didn't come with a block heater. But had one installed a few months before winter arrived.
I plug it in like 30 minutes before I have to start the tractor.
If you've ever go to Fairbanks Ak you'll see a plug hanging from the grill of every car and truck you meet.
10,183
I would add that it's better for batteries and glow plugs too. I have glow plugs in both tractors and both trucks, and they're there to heat up the air in the cylinders to help the diesel/air mix reach auto ignition temperature. But it's so much easier on both when the engine is up around 60°F as opposed to somewhere between -20°F and 30°F. The other benefit is that the engine gets up to normal operating temperature quicker too. I have a DP-Tuner programmer and chip and the display shows coolant temperature with a verbal warning that the coolant temperature is "too low" until it reaches 85°F.
There are times when I don't have the option to use a block heater, but I try to limit those really cold start ups by using the block heaters whenever possible.
