Guess Tire Ballast?
bosshogg
2004 L3400F w/ FEL
Aug 16, 2012
231
Hartford, SD, USA
When I purchased my L3400F the rear tires were filled with a fluid. I have no idea which fluid... Drained some out and it is light brown in color with zero odor...any one give me an educated guess?
Bluegill
Jan 11, 2012
1,560
Success Missouri
Probably rim guard/beat juice.
Mine also came with fluid (clear) and after a few months I ask the dealer, they said water w/alcohol.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Light brown to clearish might be some rust. If you bought the tractor used from a private owner maybe they filled the tires them self and who knows what could be in there.
bosshogg
2004 L3400F w/ FEL
Aug 16, 2012
231
Hartford, SD, USA
Dipped some clean welding rod in the liquid for 4 hours then allowed to air dry...coating of rust. I am pretty sure it is calcium chloride. Found a Goodyear site that says rims won't rust providing the tires are filled above the rime level which mine are. In order for something to rust there has to be oxygen present... Anyhow the stuff may have been in there for 8 years so I will just let it ride knowing someday I might need some rims.:mad:
Bluegill
Jan 11, 2012
1,560
Success Missouri
Many, many old tractor tires have been filled calcium chloride and rims last for many, many years. But yes, you will need new rims at some point.
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
put a sample in the freezer, If it turns solid and you use your tractor in freezing weather its time for a different fluid.
WFM
L3800
Apr 5, 2013
1,309
624
Porter Maine
I was told my tires are loaded with beet juice up to the top of the rim. My dealer said the juice stinks also.
