GST issues on L3010
Builder Bob
L3010
Jun 4, 2018
Venus, PA
My Kubota GST L3010 recently started acting like the clutch is slipping. If I am in any gear above 2nd, and I go into a pile of dirt, the engine does not bog down and the tires don't spin, it just stops. But if I drop to 1st or 2nd gear, the tires will spin going into a load. It used to either spin or stall the motor out if you were in a higher gear. I'm trying to figure out what the issue is. Being a GST, there shouldn't be a direct clutch drive line - right?
11,550
Yes your tractor has a mechanical clutch and yes it does sound like it's going out.
You can confirm this if you have a PTO power implement, put the implement on it, spin it up put the tractor in a higher rage and drive into the dirt pile, if the PTO power implement shaft slows drastically or stops spinning all together then it it's 100% the mechanical clutch.
If it stays spinning then you have a GST clutch pack issue (very very rare). ;)
