Grey market L1-205 transmission
T1460
T1460 / L1-205 sunshine
Sep 25, 2024
Saskatoon
Just got a new to me l1-205 and am curious. Is this a mechanical shuttle shift,where you need to clutch every shift? Or is something not right that I can’t shift fwd/ rev without clutching.
Can operate as is but would like to add snowblower and clutching disengages the pto.
2,005
I think it is a standard gear drive transmission that needs to be at a stop and clutch depressed for every gear shift,
Why do you think it is shuttle shift?
T1460
Sep 25, 2024
Saskatoon
I has 4 ranges
As well as 4 gears per range on the column and then on the left side of the column there’s fwd neutral and reverse lever.
8,700
I'm pretty sure that is a full mechanical shuttle, you need to clutch on every shift and every shuttle.
The dutch guy
Kubota new Sunshine L1-225 with a Cochet FEL, flailmower, Tiller, chainharrow.
Jun 4, 2025
9
24
The Netherlands
i own a L1-225 and can confirm it is a mechanical shuttle shift. Clutch needed with every change of direction or gear. You need to completely stop before shifting.
