Grapple. Wins and Losses
NorthwoodsLife
Oct 15, 2021
1,053
1,001
Wisconsin
So, I got a grapple with my latest Kubota. I wasted money. Because I also got forks.
I had never owned a grapple on a tractor prior.
But, I've found that there isn't too much a grapple can do more than forks and the standard bucket.
I'm glad to have the 3rd function for my future snow blower on my LX2610. But the grapple is wasted money for me.
The forks do everything, and the bucket fills in difference.
I spent too much time on YouTube before this latest tractor purchase in which I demanded a grapple. Wasted money.
B737
LX3310
Jun 9, 2019
2,024
2,200
disagree.
can you pick up leaves with forks? :ROFLMAO:
chicks dont smile when you make them use forks, they want grapples.
Reactions: 9 users
DDCD
1964 MF135, L2501
May 8, 2021
160
179
Oklahoma
I've seen the "use the forks as a grapple" argument many times on this forum. I can guarantee you my forks wouldn't have dug up a tree stump, or dragged logs out of my creek.
The picture below was after I tried to move the posts with my forks and they kept falling off.
If you don't need it, nows a good time to sell.
4,211
Depends on what you do with it and how much. Glad I have mine. Would definitely still have a grapple, forks, and bucket if I could redo the whole deal. But it’s too expensive of a piece of equipment to have just because it’s “cool”, particularly if you figure in the cost of the third function if that’s the only reason you’re adding a third function.
They are an implement with reasonably strong demand so seems like you should be able to recoup most of your wasted money by selling it.
Edit: OK, since everyone else was posting pics while I was typing….
You can’t rip a scrap drop in stove covered in poison ivy out of the ditch where someone tossed it at least 45 years ago and drop it in the back of your truck without touching it if you just have forks. And yes, I had enough oven filled ditches covered in poison ivy (along with a few other more normal jobs) to justify the cost of a grapple.
Reactions: 6 users
Freeheeler
b2650 tlb
Aug 16, 2018
706
523
Knoxville, TN
In my world there is not much a grapple can do that forks can't, but there are a lot of things forks can do that a grapple can't. Then again, my world includes forks and no grapple. I ended up spending my grapple money on a 2 post car lift instead. My world is happy :cool: I'm sure there are lots of folks living in their happy worlds that includes their grapple.
Elliott in GA
Mar 10, 2021
742
721
North Georgia
I have moved many things with my grapple that forks: could not have moved or would have taken an inordinate amount of time to prepare/load.
I do not have forks, but I have used my grapple to unload/transport an unevenly balanced nearly 500 lbs. 11 foot long pallet of steel tubing. I used a $30 lifting strap and a clevis to remove the pallet from the rear of an 18 wheeler trailer, and then I transported it more than 1/4 of mile to the build site. All I had to do was wrap the lifting strap through the pallet, and I used my grapple to grab the loop above the pallet.
B737
LX3310
Jun 9, 2019
2,024
2,200
this thread is going to a minimum of 6 pages
Reactions: 7 users
Daferris
LX2610
Nov 23, 2021
483
403
Mid-Michigan
I have a grapple and forks. There is a place for both. But in my case the forks are used once in a blue moon. The grapple is on the tractor as much as the bucket. The stump grinder is also a huge labor saver for me...
radas
Mar 21, 2022
719
833
I don't have a grapple, but I also don't have a lot of property so the forks I own have done what I wanted them to do. That being said, I could have used a grapple in a few situations that would have saved me some time. I am going to improvise and weld a thumb bracket to my forks so I can use them as a grapple when I need the functionality.
I have used the forks more than the bucket in the last 25 hours of operation. Forks are a godsend.
Nicfin36
Jun 19, 2019
1,016
466
Decatur, AL
I think the OP is yanking our chain, but maybe not. I consider my grapple the most important loader implement I own. However, I also consider a set of pallet forks an essential piece of equipment. While I don't use my forks often, they are handy when I do need them.
bird dogger
Vendor Member
Feb 24, 2019
1,597
1,456
North Dakota
It's tough navigating through the trails with a big grapple load when cleaning up the woods! I find keeping the loads to a more mangageble size like this helps.....even though it might take a little longer! :LOL:
Reactions: 8 users
ayak
L3301 HST
Feb 16, 2018
607
814
WV
I used my forks to get my new grapple off the freight truck, when he showed up without a lift gate 😁
Then I started using my new grapple to do tasks that in the past when done with forks, had a much greater chance of ending with my head being pushed out my butt.
I use both.
LarryBud
L3130
Dec 5, 2020
241
127
Cleveland, MO
I'm biting on a post which is designed to stir up things but here I go....... I can't imagine brush management without a grapple. I suppose if you're not moving trees / branches around and just unloading stuff, you could get by with forks alone.
NorthwoodsLife
Oct 15, 2021
1,053
1,001
Wisconsin
Not yanking anyone's chain, Except my own literal chain when I secure 3 times the load of cut branches on my forks vs using the grapple.
I just wanted to learn by hearing everyone's input.
I think that the biggest issue with my grapple is that the lower tines are too short. I have to come down from above to grab a load.
Whereas with my forks I drive under the pile. And find the forks far more useful for other transport duties as well. Like removing the log splitter beam from my truck.
For moving cut rounds and earthwork it's the bucket.
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
540
302
Mandeville Louisiana
Sell it!
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,809
2,822
If you are interested in selling it, let me know. I'm in N. VA and if you aren't terribly far away I would drive for the right price.
4,880
As the OP found out, for HIS application, that style of grapple , doesn't do what he was led to believe it should. Everyone's needs on their properties is different,so best 'tool' selection can be a challenge.
I've used forks for 3 decades for all of the pictured uses and dozens more. It's what I have, the jobs need to be done, and they were.
comment about the 'will forks pickup leaves' post. The 'cheat' is the orange snowfencing. The grapples didn't really pickup the leaves.
comment about the post carrying. Can clearly see the posts are not centered in the grapple. I've hauled 3200# logs on forks,centered/balaced,1/2mile out of bush,down road, to mill with no issues.
Yes, a grapple is a nice tool, just not the one NEEDED for the OP's operations.
