Dang flat face quick connects.
whatsupdoc
L3302
Jul 9, 2024
102
111
Rant on.
Every time I want to use my grapple I have to think about it hard due to the
almost impossible to press on flat face quick connects.
Even with turning the ignition on and pressing the control switch to dump the
third function pressure its still a bear to get them on.
I was so tired from working my ass off for three days all I had left to do was to dump a large couch into a dumpster and the grapple would make it real easy. I thought just use the excavator to do it but its slow and it was a 650 yard run back and forth.
After 15 minutes of trying to push that crap on " I should of used the excavator" they finally
got connected and the tractor did its thing.
Either I need to work out with weights or get something to help with the evil
flat face connectors.
Rant off.
8,734
Rant on.
Rant off.
When you take it off connect the two lines together then they won't lock up.
3,587
I seem to recall that they make a coupler that allows for much simpler/easier connecting and disconnecting?
Sort of a "push and pull" thing where you can actually connect and disconnect while it running even.
Don't remember the name of them though.
GrumpyFarmer
3,993
You might check and see if they have a tool that would help? they have several different tools…might be checking to see if they have a solution for your situation / set up.
Old Machinist
May 27, 2024
391
423
NE FL
I've seen listings for "connect under pressure" flat face fittings. I don't have any experience with them. I always thought the flat face were supposed to be easier to connect than ag or iso.
My tractor and grapple have the ISO poppet type connectors. On the grapple end all I have to do is smack the male poppet against the frame and it relieves the pressure buildup if it has any. On the tractor end I just shut it off and operate the diverter valve and loader handle.
5,681
possible option ??
maybe get an SSQA 'pallet fork' ? kinda sounds like you don't use the grapple too often as it's a PITA but forks are easy, 30 seconds.
3,445
I have the Pioneer ”quick couplers” ….. (4000 series I believe which has a ball tip instead of the “tit” shown)………..and ran into the same problem. Despite relieving the pressure on the shut-down tractor (wiggling the FEL joystick)…. I still couldn’t get those damn things to re-connect….. UNTIL … I “hit” the little ball on the male couplers with a hammer to relieve the pressure on the mower. THEN it was a piece of cake.
I suspect that the flat couplers will need to be depressed with a screwdriver or such.
MtnViewRanch
867
305
Lakeside Ca.
Rant on.
Rant off.
Here ya go.
Showmedata
LX3310
May 18, 2022
202
169
Boulder CO
I suspect that the flat couplers will need to be depressed with a screwdriver or such. View attachment 157501
I've only had to do this once, and I learned to either put a rag over the male connector before whacking it or else be *really* mindful of which way it's pointed because the fluid sprays out pretty impressively.
NorthwoodsLife
Oct 15, 2021
1,232
1,218
Wisconsin
Mine look like those. I put my grapple on this morning and right after pushing down the fel quick connect levers the hyrdos plugged right in..... WITH the tractor running AND EVEN with the fel up in the air. Amazing. 80% of the time it's a piece of cake. 20% of the time it's a bitch.
