Hi
I need help in figuring out how to remove the dash and cowling on a L4310HST. The glow plugs indicator stays on for 5 minutes after starting the tractor. I talked with the local tech and he said to replace the relay first. Form the research I've done, I can see that it is behind the dash on the right hand side. When I tried to remove the cowling, there seems to be a bolt or clip right in the middle that prevents it from lifting off.
Any help would be appreciated.
Gary
Gary
