Glare Ice Solution
Tim Horton
260
45
Lake Superior
Earlier this fall I got a Piranha tooth bar. There are 10,000 posts about them. About 60% of the reason I got it was to be sacrificial and not ware down the cutting edge on my FEL bucket moving snow on our long gravel drive. It works well moving snow AFTER you do some learning curve of how to set the working angle and remembering it is out in front of your usual bucket edge. It is easy to have it gouge the driveway until you learn to use it.
So now we have a good solid base of frozen ground and packed snow to work with for the rest of winter.. Problem is it went to glare ice on a bit warmer day a while back. A real broken hip type of dangerous.
With the tooth bar on the loader bucket, I tipped it at about a 45 degree angle and back drug it on the glare ice of packed snow on the driveway. It seemed to work well. It worked best to go 2 directions with this pattern at 90 degrees down and across the drive and yard.
Today I did this procedure again. This time I tipped the cutting edge about 60 or more degrees from flat. As I have a more solid base frozen down now this worked well. Again dragging both ways down the driveway and across the driveway making a checked pattern of grooves in the ice.
The secret to making this work is to not take too much weight off the front tractor wheels so you still have some steering control. Better to make multiple passes.
DO NOT, repeat DO NOT go fast. Take is slow and easy as a ridge in the ice or a low spot will make the tractor front end skate sideways. You don't want to be going fast if/when this happens.
Traction is not a problem as I have heavy duty V bar ladder chains on loaded turf tires.
Next summer I plan to build a clip on bucket attachment with more ice cutting edges than the 8 edges on the tooth bar. I'm thinking 24 - 25 or so edges 3/8 thick across the bucket front.
Of course we use salt, sand, wood ashes, all the usual ice aids in the areas we use the most.
Tips, tricks, suggestions, experiences good or bad.
My 5 cents of experience.
Dchemphill1
L3901HST, brush hog, L525 loader, rear blade, forks and bail spike
Jun 9, 2016
95
31
Fort Calhoun, NE, USA
You could just put fire place or wood or corn stove ash on the ice it gives an amazing amount of traction. However it may be more fun playing on the tractor.
dalola
BX2380 w/FEL & Woods RM48 RFM, Yazoo/Kees Max2 ZTR
Jun 30, 2017
316
My thinking also....why all the work? When it comes to ice, chemistry beats iron.
I also suspect tractor play time. :cool:
6,394
I use a spring tooth cultivator with narrow chisel tips to cut grooves in glare Ice. ;)
Tim Horton
260
45
Lake Superior
What about a rear blade ?
My experience is it works well moving snow, and to a point taking high spots and ridges off the ice. Not much more. At one time for an older tractor at another place I had a homemade comb type of attachment that clipped under the cutting edge of the rear blade. It worked pretty well to etch ice and manage a gravel drive. I may consider that option again depending on fabrication materials I can scrounge at the time.
Yes.. More seat time is always a good thing. :D
A funny aside. Many, many years ago my big brother taught Korean karate. Being a big guy, I was the practice "crash test dummy" person for the class many times. Thing is there is an art to learning to fall down to minimize hurt. This instinct has helped save my bacon many times over the years.
