getting ready for snow..
tghs
bx23sl
Jul 17, 2025
56
129
Raleigh NC
luckily last weekend we only got sleet and a little freezing rain,, this weekend they are calling for snow,, did a quick little fab and mounted a strip on the buckets edge, I think my neighbors will be surprised when I start clearing driveways,, one or two of them shouldn't be out shoveling..
JimDeL
Aug 31, 2022
411
465
Austintown, Ohio
HDPE? I've been using a strip of ¾" HDPE - with the edge beveled - for the past four years. I put it on around October and remove it About April. Used mostly on asphalt, it shows minimal wear.
pigdoc
G1800S L2500
Aug 19, 2022
378
318
SE Pennsylvania
Ya, I'll bet you'll be surprised at how quickly the polyurethane wears out.
When I was a kid, Dad had a line on used "grader blades". He must have gotten these from county maintenance for scrap price. We got about 50 of them. They were hardened steel, 8 feet long, 3-4" wide, 5/8" thick, with a bolt hole in them every 8 inches or so. We set them on end in concrete for fence posts around the feedlot, and bolted cattle panels to them. We also used a few of them to replace the worn out edges on our blades and buckets.
In Iowa, where all the secondary roads are gravel, the county must have used up a LOT of grader blades...
-Paul
9,991
Polyurethane comes in all different levels of hardness.
Polyurethane is generally considered the best plastic for a plow blade cutting edge, offering superior durability, flexibility, and abrasion resistance compared to alternatives like UHMW or HDPE. It is highly effective for protecting delicate surfaces like pavers, stamped concrete, and asphalt, while resisting damage from obstructions.
BX23-S,57 A-C D-14,
6,006
I bought a 'slab' of UHMW 1x4x48 for my BX23S. Already shows signs of wear, though I do 7-8 rural sized paved driveways. Good news is one neighbour has LOTS of it in his garage attic, so come Spring, I'll be getting a lifetime supply of them. Those will use carriage bolts NOT plow bolts (from the Kubota HD edge). easier to install.
JimDeL
Aug 31, 2022
411
465
Austintown, Ohio
Nice to have a steady supply.
On mine, I drilled deep enough to sink the bolt head plus a washer and used a washer and nut on the top side. I used ½" stainless hardware. Makes it easier to take it off in the Spring.
