Example: Kubota 7060 has 71 engine hp and a 4-cylinder 203 CID engine. Chevrolet made a 250 6-cylinder that produced 155 hp that they put in their pickup truck. What's the deal?
First off not to many companies will make a one off engine for an application! Parts redundancy for cost savings!Nice tractor MaleHoe!
Okay, back to the topic...
Kubota M7060 Diesel 4 cylinder 203 CID rated at 71 hp, turbo charged.
Kubota M6060 Diesel 4 cylinder 203 CID rated at 63.3 hp, turbo charged.
Why the difference?
Hp for tractor in your photo built in mid to late 40's maybe to early 50's is more than HP you listed for the JD A tested on Jan. 1,1934 when Nebraska test was performed. JD produces tractor models today with a 4.5L(276 cid) that can reach 100 hp or a little more.My grandparents farm had all 1930's - 40's John Deere tractors when I was a kid. The main work tractor was the Model A and G.
John Deere A
Drawbar (claimed): 18 hp [13.4 kW]
Belt (claimed): 24 hp [17.9 kW]
Plows: 2*14-inch
Drawbar (tested): 18.72 hp [14.0 kW]
PTO (tested): 23.63 hp [17.6 kW]
That's why tractors have 3 different hp ratings.Really hard to compare engines based on HP only. My 14hp B6100 has way more power then it does traction, regardless of how much weight i put on it. My 23 HP Lawn tractor on the other hand, couldn't pull an ant from a mole hill. Same thing with a new 22HP SCUT that I borrowed, just didn't have the same kind of pulling power.
This is why you saw HP numbers disappear from snow blowers and you started to see displacement or torque. Manufactures were inflating numbers in their favor.
