Good evening all. My G6200 was low on power so I decided to investigate. I removed the head and everything seems to be fine. I should have started with fuel but hindsight is 20/20. I switched the fuel lines around so the injectors are facing outwards. I now can not get fuel to the injectors. The only injector getting fuel is the rearward most injector and it's not even getting much. I have bled the line at the pump and it is definitely getting fuel. My question is, what drives the injection pump? I'm cranking the engine without the head but I can't imagine that would effect the injection pump? What am I missing here? The tractor ran before so I'm sure all injectors were getting fuel.
