G5200H 1000 hrs and change on meter. Wife ran it out of diesel and hasn't ran right since. I had recently changed water pump and cleared radiator to cure overheating. Now it dies under load and just doesn't seem to be firing right. It will idle fine and doesn't stall unless it's under load. I cleaned air filter and even removed but no difference. Fuel bowl seems fine. I popped lines loose and fuel seems to be pumping out just fine. There is a little smoke when you first fire it up but it goes away quickly. I would appreciate any advice. In the meantime I am going to purchase a service manual and start chipping away at the obvious things.
thanks
Matt
thanks
Matt
