G4200 & G5200 No dash power
Jimil
L225DT 3-G5200 G4200
Nov 6, 2016
North Henderson
Broke key off in ignition on my G4200. Took ignition out and to a lock smith. He removed broken key and made new one. Installed ignition back into tractor. Now no temp gauge, glow plugs and no oil light. Tractor cranks and runs. Pulled battery from my G5200 and removed ignition switch from dash only to compare wiring connections. I DID NOT remove any wires from switch. put ignition switch back in dash. Now no glow plugs or oil light. Didn't run tractor enough to check temp. I am lost as to what happened to G5200 and G4200. Your suggestions will be appreciated.
BruceP
G5200H
Aug 7, 2016
852
368
Richmond, Vermont, USA
The G series tractors have a VERY simple , old-school, electrical system. Heck, there is not even an alternator.
The add-on safety-switches are the biggest headache to cranking the engine. (seat, pto...etc)
Did you check the fuse? If that is OK, consider consulting the electrical schematic. It is in the back of the manual. (available here ==> http://www.kubotabooks.com/AutoInde...ls/&file=G3200 to G6200H operators manual.pdf )
dlundblad
G5200, L2501, ZD1211
May 16, 2009
503
10
IN
My G6200 did this to me the day I brought it home.. It was a fuse under the steering wheel.
My dad's G1800 does this with a bad battery or poor battery connection. If it's not the fuse, I'd make certain the starter is getting 12 volts.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,242
1,026
Williamstown Ontario Canada
Did you check the fuse? If that is OK, consider consulting the electrical schematic. It is in the back of the manual. (available here ==> http://www.kubotabooks.com/AutoIndex...s manual.pdf )
Link does not work
Dave
