C chopper698 New member Equipment G4200 Jan 30, 2018 18 1 3 Mineola N.Y Feb 24, 2018 #1 Rebuilt the clutch on this G4200 that I have and when I step on the clutch pedal it's like there's no clutch at all. I have had it apart 3 times already and don't see anything I missed. Is there something or sequence om doing wrong?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 29,556 5,805 113 Sandpoint, ID Feb 24, 2018 #2 Pictures of what your dealing with when you in it would help tremendously! All I can say is you have something wrong if it's not disengaging when you push the clutch pedal.
C chopper698 New member Equipment G4200 Jan 30, 2018 18 1 3 Mineola N.Y Feb 25, 2018 #3 The previous owner apparent shortened the rod underneath that goes to the peddle. I had to make a new one from scratch. Now it works as it should.
eserv Well-known member Equipment BX24, A1000 Kubota Generator May 27, 2009 2,136 135 63 Hardisty, Alberta Feb 25, 2018 #4 chopper698 said: The previous owner apparent shortened the rod underneath that goes to the peddle. I had to make a new one from scratch. Now it works as it should. Click to expand... It's a good thing you had some scratch laying around!
1 100 td Active member Equipment B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat Aug 29, 2015 1,776 8 38 ɹǝpunuʍop Feb 25, 2018 #5 eserv said: It's a good thing you had some scratch laying around! Click to expand... Lucky all right, bloody hard to find at times!
