Hello,
First post in forum. Sorting out the issues with a newly purchased, well used G2160 and the only remaining bug is giving me fits. If cruising forward then releasing the pedal, the machine only slowly reduces speed. I'm having to apply a slight bit of reverse to slow it down and stop. No doubt all of the linkage is clean and well lubricated. With the engine off, its clear the pedal springs quickly to the neutral position. I went through the neutral setting procedure in the WSM. Problem persists. The fluid is a bit dirty so Super UDT and a filter is next, but I just have a feeling this is something more serious. Could I be overlooking an adjustment? Is this a sign of wear (just under 500 hrs. on machine). Is there an additive that may help? Thanks much.
