G2000 relay / regulator help
scopeman
G2000
Jun 7, 2014
14
Greer
Hello all,
Does anyone know or where I can find out how to test for a bad relay box or V regulator for a G2000? I started out with a problem with the fuel and temp gauges not working but was told they did off and on. I have removed all the connectors and put no-ox in them, the two lights on the dash come on and I hear the relay in the box, but when I try to crank, I hear the solenoid click and the lights go out and dont come back on. just not sure about the relay/reg.
Thanks in advance.
Kendall
6,710
That sounds like a bad ground, or loose connection in the wiring :)
Tooljunkie
May 13, 2014
4,150
That seems like a bad battery/ poor connection.
I have seen many batteries that have good voltage, but go open under any kind of load. Its a common failure.
Resistance tests for ground/ power circuits are next.
scopeman
G2000
Jun 7, 2014
14
Greer
Thanks for the reply back guys! the ground wire at the frame end (connector) had Intermitting problems!! Replaced cable with some #2 i had and fix the start /lights problem. but temp and fuel gauges still no go.
