G1800 ??s
5,506
2,213
My Mom's G1800. The "aux pump" on top of the transmission leaks. The rear seal is allowing fluid to weep past and it covers the top of the transmission with dirt/fluid. Kubota wants $46.00 for the seal and messick wants $15 to ship it (a seal the size of a half dollar). Anyone know of a cross reference? I can't see any numbers on the seal itself and I haven't pulled it yet to measure it.
Second question. Same mower, the lift cylinder leaks a little bit. $1400 from Kubota, they don't show any parts available for it. Is there any other option? Because mom's definitely NOT going to put $1400 into this thing, that's more than the mower is worth. She really doesn't need a mower built like this anyway but I can't get her to try a zero turn or I'd give her my zg127 and pick up something else.
There is other issues with it as well but I think I have those all figured out, all minor. Last year I had to rebuild the engine and that cost less than that lift cylinder....
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
232
250
Pennsylvania
I think if you pull the seal, take it to a NAPA store and, I bet they could match it up. Or before that, a couple drops of brake fluid on the seal lip will allow it to swell...only a couple drops
MessickFarmEqu
All of it
Apr 16, 2010
PA
www.messicks.com
if you call and ask the parts tech on the phone to ship it US Postal, they will. By default we assume you want things quickly and use a 2-day Fedex service.
