Anyone here know the specific bearing number for the needle bearing on a G1800 PTO shaft? Not the Kubota#, the actual number on the bearing itself from the bearing manufacture. The front bearing is a 6205 RS. The rear bearing is a needle bearing and is hidden behind a seal. The shaft has some wear and I can have that repaired for cheaper than a new shaft and install a under size needle bearing. But I need to know what bearing is used there, to reference from. I don't want to tear into the needle bearing or seal yet, because it will be destroyed most likely to get out of the housing. I am still using the tractor and want to get parts ordered ahead of time.
