Anyone have a reason why the 10amp relay fuse keeps blowing on my 2006 bx 23? I removed the seat kill switch and no luck . This IS the fuse running the fuel shut off solenoid. I placed a resetting fuse link and it doesnt work either so almost sounds like a direct short. Only does it when it starts. If i place a new fuse in it but dont start it the solenoid will work forever just turning the switch on and off but as soon as it starts it pops that fuse and i have to use my hand to shut tractor off. What else does the fuse run or where does the wire go off this fuse? Ready to put a push pull chake on it to control the shut off manually......
