Fuel Starvation?
Tom Joad
Kubota M6060HDC
Sep 29, 2024
Louisiana
I have a 2017? M6060HDC that loses power and runs rough after running approx. 5 or 6 minutes at constant high rpm (as in bush hogging, etc.). I have noticed that the water separator bowl will not be completely full after it has lost power. I have removed the fuel tank to check for debris, replaced the fuel filter, replaced the fuel line between the tank and separator, disassembled the water separator to check for blockage and blown out all remaining fuel lines with compressed air, inspected the tank vent, tried running the tractor with the fuel cap off. To date, I haven't replaced the electric pump.
I have followed similar threads and tried suggested remedies to no avail and I'm seeking advice from someone that may have had experience with this particular malady. Any pertinent ideas will be appreciated. Thanks.
