All - am a new-bee to your forum. Found it while Google-ing for any online information.
I have a nearly new (<20 hr) D1105 with a 8 Kw Pancake generator attached. This rig
is from a TEREX light tower. After sitting for 2 months - I tried to start via my normal
startup procedure. Turn on ACC power, prime the pump - hit the starter. No go.
Primer pump is not filling filter & main pump body.
I removed fuel return line - nothing -> hence pump is not engaged. I pull wire harness
on fuel cutoff solenoid, hit prime -> I get 11/12 volts. This is good. Am getting juice
to solenoid - but no action. I did measure resistance of Solenoid.
As of current - I think that I have a bad solenoid --> but after only 20 hours ??? These
bad boys are expensive, is there someway to verify that the solenoid is bad ? Is there
some way to override to test theory ?
As I understand function -> when I hit the pump , the solenoid engages, pulls
back a pin & lets fuel flow.
Any help is appreciated - Thanks in advance.
MM
MM
