My 7040 has a start issue. The Fuel injet or pump does not open when I turn the key to on position. I opened the inspecation port and notticed I could move it with a screwdriver a little bit and it started immediately. Noe that has ceased to happen. Now it is stuck closed when the solenoid is energized. I removed the solenoid to prove its function and its Perfect, but the rack seems stuck. I lubed it with WD40 but nothing. How do I proceed. The Dealer says I need to remove the Injection Pump and take it to a shop to figure out what’s broken. Any Help would be appreciated. I dont know how to remove the pump. It looks impossible.
