Fuel killed electrical
Sampsonight
B7200HST B2551
Jan 6, 2022
Maine
So as I was fueling up my B7200HST my spout broke and a good splash of fuel spilled down the right hand side of the tank. When I turned the key to check fuel level, none of the gauges would work, lights are all dead, and the worse part (live in cold climate and snowblow with the tractor) the coil heater won't work.
The ignition does still operate and I can eventually get the tractor going but I need to get this resolved... This happened about 1 week ago, so any fuel should have dried off by now. What do I need to check/what could have happened? Thanks
2,540
Have you checked all the fuses that are under the dash?
I would get under the hood and painstakingly look at each wire and the fuse that goes with it.
2,963
Would not have expected fuel to cause an electrical issue. Unless it carried some contaminants that shorted out electrical connections.
What is a coil heater?
Does the tractor still work with the engine running? IF so you are at least in better shape that if the tractor would not start to begin with.
Hopefully someone will give you better help, since I really have none, except the thought that I would use the tractor as is if needed, if it worked for me, even without gauges...
kubotafreak
Sep 20, 2018
1,048
393
Arkansas, US
Many times fuel pumps have exposed connections. I doubt the fuel bridging any circuits broke anything. You sure the ignition isnt just getting sticky. Electrical contact cleaner may help you.
6,286
Diesel doesn't dry up.
Diesel fuel should not effect anything electrical, wiring or components.
But stranger things have happened.
Have you inspected the wiring and fuses?
Sampsonight
B7200HST B2551
Jan 6, 2022
Maine
Checked all fuses. Everything was good, tried key, still dead. Took the dash apart, unplugged and cleaned everything I could and reattached. Working fine now! Also regained my flasher lights that had not worked since I bought the tractor! 😅
4,888
re:
so a 'preexisting condition'
sounds like the first time it's ever been cleaned ??
how old ??
you can get a LOT of dust and crud and gorf into the wee nooks and crannies then one day ,oopsy...it don't run...
