Fuel issue on m8540 cabin
HERC
Kubota m8540
Nov 9, 2023
Croatia
Hi! I am from Croatia and sorry for my english, i don't use google translate. I have M8540H-C cabin model from 2011, v3800-DI-t EU8 motor.
I finished last year with about 12 galons of fuel in tank. Worked this spring about 1 hour and get signal on dashboard for low fuel. Whent to gas pump and filled to top whith bout 80 L diesel. Came home, and tomorow tried to start tractor first time ok,and after 1min i shut it off and try again but nothing.
Turn key to ignition its start to cranking but motor won't start. No smoke from exhouse. Battery is good 12.9 V, change water separator, it was dirty, few drops of water.
I have fuel all way to injector pump. When i turn key i hear "click" from fuel solenoid and also i feel under fingers when solenoid " work".
In cabin on meter panel when i push together two button there are no1, no2, no3, no4.
No1 i have 0.17v is that important data for fuel solenoid?
In Croatia Kubota is't so common tractor so when problems start it is pain to soleved, please can someone help me whit this problem?
