Fuel gauge on bx2370
dfh1977
198
east ky
Last time i used tractor around yard and change the hst filter. Noticed fuel was low to point that fuel light came on then go up 2 notches. Of course i figure time to add fuel if low. So i filled it up to full tank and close diesel cap. Let sit a couple minutes while cleaning up mess from maintenance work. Went to start tractor to park and it still registers at 2 notches instead if full tank. Tried search for answer but it was an older post about having to remove fuel tank and i just wonder if there could be just a loose wire to check by chance. Google not much help either. No trailer if it has to go to dealer for repair.
sagor
Jan 9, 2017
285
58
Sudbury, ON, Canada
If it was a wire problem, it would go either empty or full scale. I tend to agree with D2cat that it is a stuck/sticky float inside the tank. Drive around on some bumpy areas and see if it loosens up. Changing it is a fair job, to get to that tank....
dfh1977
198
east ky
Ok will just trust for now but if not resolved after a few uses then dealer gets a call for repair job.
