I have had a 1996 L2900DT for 10 years with 1150 hours. About 9 months ago, I noticed temperature gauge pegged in the red hot zone. I replaced the thermostat and thought I had fixed it. I did not use it much over the winter, but this Spring the temperature gauge pegged in the red again. I took it to a local mechanic who thought it was from a blown head gasket or cracked head. He inspected the head and replace the gaskets. It continue to peg the red zone after 1 to 1.5 hours. He then replaced the radiator and temp sensor without benefit. I decided it was too expense to let him continue replacing parts. I bought a thermal gun and discovered that the tractor was not hot. The block read 175 - 185 when the gauge was in the red zone. The radiator read 154. I have check this multiple times and the tractor is not overheating. 2 days ago the fuel gauge started pegging the full mark after 35-40 minuets followed by the temperature gauge going in to the red zone after 40-60 minuets. From what I read, both gauges will peg full or hot if the wires go to grounded. Has anyone had this problem and know how to fix it. I'm wondering if I have to replace the wiring harness, but this would be expensive. I've thought about replacing the electric temperature gauge with a manual gauge but that does not solve the problem with the fuel gauge.
Thanks
Thanks
