Fuel blockage in tank
Springer
BX2680 LA344S EA 55" Grapple, Stump Bucket 48 Box grader, Disc Harrow
Jul 21, 2021
98
56
Tiger, GA
I have a little bx-2680. 70 hrs old
Last year it would run and then start surging and sometimes shut off. I changed the filters and the fuel pump with a after market one on Amazon. When the tractor shut off, I noticed the fuel pump was warm to hot. But the problem returned almost immediately or rather never stopped.
Today I drained the tank and bought new filters and fuel pump. This is the $207 pump from Kubota.
With the filters and pump removed, I thought I better flush the tank with something. I found a half gallon of diesel treatment, in an unopened bottle.
With the wife watching, I poured the treatment into the tank but it only dripped out the open line?? I started up the compressor and used a big piece of foam rubber to seal the tank inlet and blasted air into the tank. My wife said that the dripping was faster but not flowing?? I could feel the tank blow back when I removed the sponge.
I crawled under and put my air hose in the tank outlet. I blasted air and could hear the fluid gurgling in the tank. When I pull out my air hose, the diesel treatment fluid came out like a cow pissing on a flat rock!!
I blew something loose. But what? Again I blew into the tank inlet and all the fluid came through. I replaced the filters but kept the pump out until I get some advice.
I don't know what was clogging my line of tank. I don't want to button it up again and have the problem return. I also don't want to gum up a brand new pump.
I research taking off the gas tank but that sucks. I was hoping to pull it off and clean it thoroughly but I basically have to tear down the whole back end. Should I just put it together and hope for the best? Add more fuel treatment with a fresh tank of fuel?
The fact that I only have 70 hours in 4 years might explain it. But I do treat the fuel in the winter and I'm in North GA so we don't see much winter. And I keep it in a car port.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,963
2,421
Near Lancaster, PA, USA
Have you been using algaecide? With the fuel usage that low my bet is you're growing colonies of "crobies" in the tank. I'm betting someone on here has a good method of killing the slime and cleaning the tank without removal.
Hugo Habicht
G1900
Jun 24, 2024
1,116
1,612
Ireland
You could get one of those USB inspection / endoscopic cameras and look into the tank:
You should be able to see if there is any growth or something floating around and possibly be able to siphon it off with a hose.
I use "Grotamar" for algae growth prevention in devices that are not used a lot and hence do not see a lot of Diesel consumption. It is also suitable for treatment with a higher dose they claim, but I do not know how efficient it would be and if it would dissolve major growth.
jaxs
B1750HST
Jun 22, 2023
1,007
777
There's often a strainer/sieve to catch large debris. I would expect it to glogg again shortly unless debris is removed from tank.
Old Machinist
May 27, 2024
580
683
NE FL
I cleaned my JD tank out with a shop vac. It smelled like diesel for months. You can probably prevent that by rigging up a remote vacuum reservoir with a 5 gallon bucket. Or just buy a cheap wet vac and don't worry about the after smell. It eventually wears off.
Or just remove the vac filter and wash it out with detergent afterwards.
Springer
Jul 21, 2021
98
56
Tiger, GA
I am up and running again. What I had was a gel formed by diesel fuel and whatever - probably moisture and biologics. It formed about a pint of what looked like jellyfish. I managed to dissolve diesel fuel treatment. In the process, I replaced the fuel pump and filters. I suspect that that was over-repair in that that is the third pump on the tractor. I doubt any of them are bad. They are not cheap so I put them on the shelf for future repairs.
I don't see cutting a clean out in the tank now that I know the cause. In fact, removing the first filter and flushing the tank is pretty trivial now that I know what I am doing.
Thank you guys for your help.
While crawling under the tractor, I was thinking how much I loved working on my old wrangler and harley and hate working on a kubota. The first two were planned and made to be worked on. The later was not!
Springer
Jul 21, 2021
98
56
Tiger, GA
The BX has a straight shot 4 inch hole. I do strain thru a filtered funnel though.
