front wheels on BX1880
Bearcatrp
Mar 28, 2023
912
573
Minnesota
Get the set that goes on the 23S. That what I did so I could get R4 tires. If you look underneath at the rear axle, it will show 23S. Gave me about a 3 to 4 inch lift. The ratio from front to rear has to be correct or your 4 wheel drive will bind. Just remember the higher you go, the possibility of tipping over increases. I put the R4’s on for winter duties.
