Front Tires
10,139
Is yours a 2wd or a 4wd and what is the size / type of your current rear tires?
10,139
Love the rear tires!!!! :cool:
You can put whatever tires you want on the front. :D
It came with, 4.00-12 but since you up sized the rear, upsize the fronts.
I would put a set of skid steer/ industrial tires on the front to hold the load better with a loader.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
Since it is a 2WD, size is not critical. What you are looking for is a good load rating. Generally, industrial tires give it to you. I'd go have a look at what your nearby Kubota dealer puts on the front of a tractor with similarly sized rear tires. My L3200 came with 27x8.50-15 industrials. Go for at least 6 ply rating.
You can get good prices on ebay, for tires mounted on wheels, ready to. Measure your center hub cutout, and the bolt pattern. They'll fix you right up. I personally like tuckertires.com; other threads here recommend other dealers.
You can also just go for the industrial tire that will fit your rim, in a 6 ply rating. Give them a call.
Nice looking tractor!!
