front loader and 3 pt
jgh66
l2350
Aug 21, 2015
Acampo Ca
does the front loader and 3 pt run on same pump. I replaced loader control valves and 3 pt won't work
3,448
are you sure you have the hoses hooked up right??? Ahhh please don't ask how I know this
2,581
skeets,
you been cutting back on coffee AGAIN???? :D:)
jgh66
l2350
Aug 21, 2015
Acampo Ca
I'm not sure on that. replacement control was different than original. do you know where I can find hydraulics hook up and flow
rbargeron
Jul 6, 2015
1,171
238
western ma
The original loader valve has 7 hoses - one being a "power-beyond" hose that goes back to the hydraulic block to power the 3-pt hitch. Some loader valves don't have a PB port. Some have it but need a special fitting put in to enable it. If there's a "PB" port on your new valve, run a hose from it to the unused port on your hydraulic block and the 3-pt will come to life. Take care, Dick B
6,600
jgh66,
I sent you an email of the WSM for your tractor, should help to answer some questions.
Post back if you need more help. ;)
