Front End Loader Problem
Grant City Fram
Kubota L2501
Mar 21, 2021
Indian
Hi Kubota Community,
I have a new L2501 Tractor with an LA525 Loader... 11 hours on this Tractor. Went to change an implement and discovered this problem.... when pivoting the hydraulics forward to attach the implement... the right hydraulic pivots forward before the left side... they are not in sync and consequently makes it nearly impossible to hook an employment. Any idea what is wrong here and how to get the hydraulics synchronized?
Thank you in advanced for any insight on this matter.
My very best,
Matt
3,316
I take it by your problem/description you do not have a SSQA on it? You have a “pin on” type loader?
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,410
1,691
Kalamazoo, MI
Sounds like there may be an air bubble in the lines from dealer setup. Try exercising the bucket and boom functions to their full range of motion many times to get the air pockets worked out of the system. If that doesn't help, call the dealer.
5,559
I take from your post you have a SSQA system and the plates are not angled the same. You should be able to move your loader lever until both cylinders are fully extended, then when you roll them back to get under the attachment plate they will be parallel.
ayak
L3301 HST
Feb 16, 2018
609
819
WV
If you have an SSQA, have look at this thread:
